Does anyone have an interior picture of the upper tank of a radiator for a '27 Touring? A side cut away view would be most helpful.
I have a 4 year old Brassworks radiator that has failed and according to the vendor the warranty is only good for one year. When I open the cap and looked inside I can see a large baffle or large tin plate that has come loose and is lying over the circulating tubes blocking the flow. I was thinking of attempting to unsolder the top tank and reattach the baffle if I knew how it is positioned inside the tank. This is the second problem with this tank. The first issue I had (3 years ago) was the overflow tube leaked where it came thru the bottom of the tank and I cleaned the area surrounding the tube and resealed it with metal mender. I don’t know of any good radiator shops in my area. Any suggestions would be appreciated.
Denny
