I am building a 1916 t and am having trouble with the steering bracket for the steering column to pick up the top hole if the fire wall bracket I need two washers under the front bolt on the Steering bracket is there a difference in steering brackets and steering column in the early TS thanks all
Should be the same bracket for 1915-1925.
