Hi,
I’m just checking before I fire this thing up for the 1st time.
I’ve set the new 009 distributor up so that the points (gap 18thou) are just beginning to open when the spark lever is fully retarded, with #1 just after TDC and the crankshaft pulley pin is about 3.20 & 9.20.
Is that right?
Thanks & Cheers,
Rob
Sure sounds right to me. Good luck with the initial startup! ![]()
