The rear spring clamps are loosened and the brake rods disconnected. The drive shaft and U Joint are lifted about 12" above the frame, then the engine is swung into position. You are able to easily see and insert the u - joint from the top. It takes only seconds, and you are not under the car.
See how a about 1:14 into this video:
