What is the correct resistance in ohms of the ford model t magneto?
The Model T magneto is a low-voltage AC winding, so a normal ohmmeter reading is very low—often under an ohm—and lead resistance can swamp it. Zero the meter or subtract lead resistance, and measure from the magneto terminal to a clean engine ground. More useful than an exact number is checking for an open circuit and confirming AC output while cranking. If you get infinite resistance, look for a broken connection or terminal issue.
