This is embarrassing… When driving it in high it accelerates a little then decelerates a little … continuously. Any suggestions appreciated. Thanks
Welcome to the forum! When it decelerates, is it sudden, like a hiccup or cough? That can be a sign that the mixture is lean. Have you tried turning the mixture screw clockwise a little bit to see if the surging goes away? It won’t take much, maybe try 1/16 or less of a turn.
Thanks cudaman ---- will try your suggestion. Will let you know. Carl
Cudaman… Took the t out today after leaning the cab like you said and it works like a charm! A big THANK YOU.
