How do you remove the commutator for greasing?
First remove the commutator pull rod from the commutator by removing the split pin holding it in place. There is a spring that holds the commutator in place. The loose end of the spring sits in a detent on the commutator housing and the other end is held in place by a bolt. You need to rotate the loose end of the spring out of the detent until it clears the commutator. Sometimes you may need to loosen the bolt a bit to move the spring. Once the spring has been rotated off the commutator it should come right off and can be cleaned and oiled without removing any of the wires. This assumes you have a standard roller style commutator.
